メインコンテンツにスキップ
モデル番号A1318/ 32もしくは64GB容量
299回答 すべてを表示
Lower strip is dead, how can I repair it? What is digitizer?
I have an iPod Touch 3G with 32GB and it is currently on the "Restore completed" screen, which you must press continue, allow/not allow location services, connect to WiFi, and agree to terms. I cannot press anything on the lower part of my screen (except slide to unlock) and I was wondering how I can repair it.
I heard something about a digitizer, what is that? I heard you need to check eBay for one, all I see are repair kits and screens, is that the right one?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
Hi, Matthew here.
A dead strip can either be...
1) Digitizer ( Glass display )
2) Logic board digitizer connector.
Its most likely the digitizer, However, I have had other customers iPod Touches with a digitizer connector failure which means soldering. Even though i have fixed each one 100%, its incredibly difficult.
Matt.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Is the digitizer just the front screen? If so, am I allowed to post links here? I want to know if this is the right one.
さんによる
Yes, of course you may post links. That is the only way for us to see what you see....;-)
さんによる
コメントを追加
回答を追加する
Jonathan Tran さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 804
