Determining which one of the sub-models I own.
There are ten submodels of this machine. My sticker was rubbed off many moons ago. Used the machine in the rain. Motherboard is damaged. I removed the solid state hard drive and docked it. Works fine. Now, I would like to replace the motherboard. Cannot find numbers on the board that match Lenovo part numbers.
1件のコメント
@edward78879 I believe Lenovo used a lot of Compal logic boards. Most common place for the motherboard number is on the top side. If you still have your board mounted inside your computer then you are only looking at the bottom side. Remove the board and post some good pictures of both, top and bottom, with your Question. That way we can try to assist you with finding a replacement. Or maybe even fix yours :-) It might just be NM-B451 or NM-B671 but we'll have to see
iFixitでの質問に画像を追加する方法
oldturkey03 さんによる
