メインコンテンツにスキップ
モデル番号はA1706 / EMC 3071ー2017年6月発売。この13インチMacBook ProはKaby Lakeプロセッサが搭載されています。最大4.0 GHzのTurbo Boost付き3.5 GHz Core i7です。
MacBook not charging the battery
I recently bought MacBook Pro A1706 with backlight issue, fixed it and factory reset it because the seller wanted me to, after installing the OS i noticed that the battery is not charging at all, in settings it has around 400 charging cycles so figured it shouldn't be bad, the seller also stated that it was not used for a long time, so my question is, is there any way to "jump start" the battery?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I doubt "Jump Starting" is really an option here.
A battery which is not charging is more often a bad charger or the wrong USB-C cable. Then if you have a known working charger and cable the issue is within the logic boards charging logic.
I would get a USB-C power meter to measure the voltage from the charger feeding into the system what does it tell you? Do you see any power getting to the system?
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
Charging voltage on the motherboard is 13V and something when charger is plugged (on the pins + and - that go on bms)
さんによる
@dizzyrepair - You need to trace the path looking at the USB-C input point using a USB-C power meter like this one MakerHawk Type-C USB Meter Tester
さんによる
Will check it out
さんによる
Charging is fine, however I can't comprehend the BMS, on + and - terminals the voltage is 2.18V but when I desolder main + and - terminals from the BMS I get 11.47V from all the cells, seems like when the cells reach certain level of discharge the BMS components render the battery useless
さんによる
コメントを追加
回答を追加する
Em4N さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 45
今までの合計 320
