Mine no longer play games only dvd and blueray
@edgardopaz that is caused by either a dirty or a failed laser. You can try and get those commercially available lens cleaners and run that a couple of times. If that does not work, you could try and replace the laser assembly. Not sure if you can see this guide (it's in process Xbox 360 S Laser Lens Replacement ) The other thing you can try is a pot adjustment for your laser. Worst case scenario with that is that you may burn your laser out. See if this will work for you XBOX 360 POT CALIBRATION
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 9
