メインコンテンツにスキップ
Released in 2020, the Razer Blade 15" Advanced model is designed to provide gamers with powerful specifications and sleek aesthetics.
8回答 すべてを表示
Sourcing Screws to Hold In Battery
I'm hoping to get a battery replacement for my laptop which hasn't had a battery in quite some time. However, with several moves, the screws used to secure the battery have been lost. Is there any place I can find the battery retention screws, or even just something that works as a stand-in for them?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Depending on what kind of screws they are these might fit
https://www.amazon.com/Replacement-Screw...
I would advice checking the original screws that might be left or the screw holes in the laptop with a caliper to make sure they fit
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The original retention screws were Phillips head, but I'll take whatever solution I can get. They're cheap enough that I'll buy them and give them a try. And while I don't have a caliper around, I do have one retention screw left I can compare them to.
さんによる
@nathandavi62193 I would highly recomend making sure they are the right size first instead of finding out after spending money on it. Even if they are cheap.
さんによる
コメントを追加
回答を追加する
Nathan Davis さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 20
