メインコンテンツにスキップ
2019年3月に発売されたAppleの人気ワイヤレスイヤーバズの第二世代モデルです。
28回答 すべてを表示
Can I clean the case with ultrasonic cleaner?
I already have an ultrasonic cleaner, I know the speakers are sensitive to the cleaner, so I will do that manually, but the case is dirty too, and has some rust or metallic dirt ( I guess, it is only visible on those spots)over the magnets, which are really hard to remove ( I tried but It made only a little difference) so I thought that I could use the ultrasonic cleaner with soap like chemical and deep clean it, then submerge it in alcohol to remove most of the water and let it dry for a day or so. I am pretty new at cleaning electronics with an ultrasonic cleaner .
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I wouldn't advise doing so since moisture is quite stubborn and will often just rather condense inside the case.
Ideally I would use isopropanol in the ultrasonic bath, but that is a significant fire risk that isn't worth taking.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Péter Cserkuthy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 36
