メインコンテンツにスキップ
Repair guides and support for your Samsung TV.
2614回答 すべてを表示
Samsung Samsung qled showing double image all the time (QA55Q70TAKXXL)
Samsung QLED 55 inch Q70T (QA55Q70TAKXXL)
This TV was bought around Dec 2020 in India.
Double imaging started showing a few seconds and now it's showing all the time
I attached the required images.
I also reviewed other threads regarding this. Should I change T Con board if yes, please tell me where should I buy it.
I also saw this fix in the youtube
https://youtu.be/XwG7t1FEhh0?feature=sha...
Can I try this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@sara10012 the video is referring to a Tape-off. Sure you can try it and it may resolve the issue, if it is related to a bad panel. It will not resolve it if it is a bad board. Once you have the back cover off your TV, take some good pictures of all of your boards and post these with your Question. That way we can see what you see. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sara さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 14
