メインコンテンツにスキップ
モデル番号はA1706 / EMC 3071ー2017年6月発売。この13インチMacBook ProはKaby Lakeプロセッサが搭載されています。最大4.0 GHzのTurbo Boost付き3.5 GHz Core i7です。
Help please reference codes, PPN001 y PFM006
Hello, how are you? I want to describe my problem and hopefully someone has the same one who could solve it and could tell me what the solution was in advance, thank you very much, the case is as follows, I have a macbook pro mid 2017 A1706, recently its battery stopped working The cycles were exhausted, I changed the battery, but everything was fine, I removed the previous battery, placed the new one, I closed the MacBook and turned it on, but now it takes a horrible time to start and everything became extremely slow, I performed a fault diagnosis. hardware and the result was the following with these 2 codes
PFM006: There may be a problem with the System Management Controller (SMC).
PPN001: There may be a problem with the administration system
I returned the previous battery thinking that the new one was the problem, I reset the (SMC) using the keyboard combinations, but it didn't work, in fact it doesn't perform the reset function, can someone tell me if it happened and how I solve it , someone please
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
This sounds like a sensor issue. When a Mac is missing data input from a sensor it puts the Mac into a protective state—revs up the fans and clocks the CPU way day. Which is why it takes ages to do anything. It assumes no sensor data means the worst and prepares for that.
Sensor issues are usually related to a handful of spots. It could certainly be the battery, or something that happened as a result of the replacement. First thing I would check is the data cable for the battery. It's the little one that comes off the battery board. It's not unusual for that cable to be loose after a repair. Make sure the cable is fully inserted and the little locking flap is down. This is also not uncommonly an issue with the trackpad, but based on the backstory, I am less likely to think this is the problem.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Yisus さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 13
今までの合計 463
