P0730 Gear ratio incorrect (pulley)
Hi I have a Hyundai accent to this is your card
front of me it's P0730 in gear my gear type is CVT and I don't know how can I fix it if anyone know I'll come and fix it say please do I answer this question
A logged P0730 code is a trouble code that indicates the transmission is slipping. The powertrain control module registers this code when there's a greater RPM difference between the rotational speed of the input RPM and the transmission output of the RPM sensor.
I would test the speed sensor and check the transmission fluid level first and foremost. This is an indicator of a failing transmission.
Cheers
Monte
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 11
過去 30 日: 55
今までの合計 251
