メインコンテンツにスキップ
GoogleのPixel 4スマートフォンの解体情報と修理ガイドです。2019年10月発売。
44回答 すべてを表示
Thin White wire under the battery appears broken. Where does it go?
Replacing the battery which was quite stuck to the phone case. Battery is out and there is now a white wire that was under the battery that is only connected at one end. Is it supposed to be connected at both ends? Is it an antennae?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Without photos it is quite hard to diagnose, but my best guess for a single white wire would probably be a 4G LTE antenna. They are MIMO (Multiple In, Multiple Out) and have redundancy, so you may or may not be able to continue on using it, albeit at a reduced speed.
If it isn't an LTE antenna, perhaps it could also be a wire from the NFC coil, which is located underneath the battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Joe さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 17
