メインコンテンツにスキップ
The Bose QuietComfort 35 II (Model Number: 789564-0020) are Bluetooth, noise cancelling headphones designed by Bose. The device comes with a USB charger and a Headphone jack cord, and is compatible with IOS and Android Bluetooth Devices.
13回答 すべてを表示
My noise cancellation is making a high pitched noise
Hello, I recently changed the battery of my headphones. Ever since then, my headphones have been playing this high pitched noise that only disappears when I turn off ANC. I think I messed up my battery repair by getting something too hot and I would like to know what part I would need to replace to get rid of this noise. Any advice would be greatly appreciated!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ANC uses an array of microphones to sample and create a sound wave that is 90° out-of-phase from the original noise.
Perhaps you damaged one of the microphones used for this process? It could explain why you get garbage microphone input and garbage audio output.
I do recognize that there are many components in the ANC pipeline that may or may not be the cause, but I can't think of many other options at the moment so this outlandish hypothesis is all I have to offer.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Spag Tortellini さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 18
今までの合計 34
