メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Stainless steel convection oven. Model:BOV900BSSUSC
Error code E01 (Thermistor issue, maybe). Any self fixes for this?
Breville warranty site says 'E01' is a non-resettable error and the oven needs to be sent to their repair service. Trying to avoid that, web searches point to this being a potential temperature sensor malfunction. Any chance this is something that can be fixed on my own? TIA
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
The E1 error seems to be pretty standard across air fryers and usually signifies thermistor failure as you said. You can test the functioning of the probe using a multimeter. If it is faulty, it will likely give you sudden inconsistent jumps in resistance as you heat it.
Replacing the NTC thermistor probe will likely solve your error. Here is a guide for a similar Xiaomi air fryer I recently translated from Spanish. If you have any doubts, don't hesitate to ask.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thank you, David! I will give that a shot and report back.
さんによる
@boocoo I admit the guide is originally written in quite a chaotic manner that I had to partly translate over, so I apologize for any potential confusion that may arise.
I wish you the best of luck.
さんによる
コメントを追加
回答を追加する
boocoo さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 58
今までの合計 1,504
