In my oppo phone not run updated youtube
This phone isn't compatible with this app written when I open youtube app
You should make use of the browser version of youtube. It allows for a slightly lower level alternative.
このアンサーは役に立ちましたか?
Hi @ayushmanraj,
Have you tried updating the phone's system software in the phone, you didn't say?
Go to Settings → Software update. Ensure that the phone is online when trying this.
If the phone's software is the latest version, then unfortunately you may have to revert back to the previous YouTube app that did work.
このアンサーは役に立ちましたか?
okay the reason behind the incompatibility is an outdated Android version. The Oppo A37 runs on Android 5.1 which is quite old. with that the newer versions of YouTube app may no longer support this version. possible solutions to the problem try this;
このアンサーは役に立ちましたか?
Your phone isn't compatible for this app. You also download a Vidmate app to run as youtube. This app is same working as youtube
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 15
過去 30 日: 72
今までの合計 2,951
9 件のコメント
Problems Update
Baba Ramdev さんによる
YouTube not update in oppo a37f
Muhammad affan abbas さんによる
YouTube nhi chalra
Oppo a37fw さんによる
how to fix coloros recovery
josh さんによる
Mere phone m youTube download nahi ho rha hai
Karan Mahor さんによる
4件以上のコメントを表示
