Does Fingerprint sensor works after screen panel replacement?
I Need my screen to be changed due to broken glass, i need to know if my fingerprint sensor will function as intendes after a screen replacement since i really need fingerprint scanner.
Hey, @rex50018
I've done a few screen replacements on ROG 4s and 5s, and I can say for certain your fingerprint scanner is still going to work. If you properly connect all the cables and put everything where it belongs, it'll function the same as before, or maybe even better. Just make sure there's no dust or debris covering it before you put the device back together. Good Luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 27
