Charging port clogged with debris, possible bent pins
Picked this up for cheap second hand as it had issues with charging, after looking at it there seems to be some sort of thick debris in the charging port which I think may be the root of the issue, a lightning connector doesn’t go all the way in, it doesn’t “click” like it would with a clean phone, after looking closer I’m thinking there may also be bent pins and this May be a full Charing port replacement.
If it’s just debris should a tooth pick / Compressed air do the trick?
The phone powers on and work perfectly, and can charge through wireless charging, it’s just the lighting port that is the issue
I will attach images of the port as I’m not 100% sure if they are bent or not
any help is appreciated :)
