Fuse clearing on power supply
Working on a phillips AH 578 amplifier and need help identifying and testing transistors. I can send photos if needed.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Here's the service manual for a Philips 22AH 578.
It has most of the schematics showing the type of transistors, a circuit description and a parts list.
Hopefully this is of some help.
このアンサーは役に立ちましたか?
Hi @robertsumm76795,
Found this link showing the equivalents between Toshiba transistors and European ones that may help.
About halfway down the page there's a list in which it shows that a 383P1 = 2SA835 and a 383N2 = 2SC1124.
The examples are only to give an indication of their possible cost and also to show that they have heatsinks ;-)
Maybe worth trying those
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 46
4 件のコメント
@robertsumm76795 no reason the send pictures, just add those to your QUESTION. Here is the guide for that iFixitでの質問に画像を追加する方法
oldturkey03 さんによる
In one of my searches I concluded that replacement for q203 and q204 is NTE 269 and 268. These are both darlington and might not be correct replacement. I looked uo 383p1 and 383n2 and they are in a different package m(no heat sink). Also, fuse 12 is shown as 6.3A but my unit has a 15A ceramic and it is clearing.
Robert Summers さんによる
@robertsumm76795
What is the full model number of the device if the 22AH-578 is not it?
jayeff さんによる
Originally I tried to find replacement parts by examining numbers on components. I ended up buying NTE268 and 269 to replace Q 203 and Q204 on driver board. I don't have any training on solid state components and I only have a volt-ohmeter to check. I am beginning to think the NTE's are not the correct replacements. They are Darlington. Yesterday I looked up 383P1 and 383N2 as shown on parts list but they are in wrong package (no heat sink). Not sure how to proceed. Original transistors have 359-1/m726 and 359-2/m726.
