メインコンテンツにスキップ
Samsung's first 2-in-1 laptop, featuring a 13.3" or 15.6" screen, 8 GB or 16 GB of RAM, and a choice of i5 or i7 Intel processor.
12回答 すべてを表示
Replaced screen. Touch screen no longer works. Pen still works.
I replaced my cracked screen. I thought it went well, seemed pretty simple. My touch screen no longer works though, but pen does. When I look up the driver, it says that the hardware is not connected. Any thoughts on what I may need to do to fix this? Is there some intricate piece of reattaching the screen that I may have messed up? Or is this simply an issue with the computer not recognizing the screen, and would I need to reinstall the driver?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi Cornelius,
Although I'm not familiar with Samsung's laptops, from owning a couple of their phones, I've seen that the screen actually has two separate digitizers; a regular one for your finger and a different one for the S pen. It sounds like you've got a bad connection on the regular digitizer.
Since there are only two connectors for the display, obviously the digitizer has to be on one of them. I'd suggest opening the bottom of the laptop back up so you can unplug and reconnect both of those plugs. Wouldn't hurt to clean them off with some 90% or higher concentration isopropyl (rubbing) alcohol while you've got them out.
Those flat ribbon cables can get a little tricky to get back in right; just make sure they're inserted all the way into the socket and be sure to hold them in place while you flip down the locking latch. Visually verify that the white line is butted up against the connector and is even the whole length.
Once you've done all that, turn it back on again and check to see if the digitizer is working yet. If it is, great, you're done; button it up and call it a day. But if it still doesn't work, there's always a possibility you got a bad part; about the only way to determine that is to try another screen.
If you still have the old one and it's functional enough to verify the operation of the touch screen, then plug it back in (no need to fully install it) and see if the touch screen works on the original. If it does, you'll probably need to contact the vendor where you got the replacement about getting a warranty exchange. On the other hand, if the old screen doesn't work either then you'll want to take a very careful look at both of those connectors on the motherboard and see if there's any kind of damage on either one.
Take a look and try these suggestions then come on back and let us know what you found and we'll see if we can figure out what your next step should be.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you for the advice. This is helpful. When I first struggled with the new screen, I did plug the old one back in and it was working fine. But regardless, I did as you suggested and cleaned off the connectors. I tried again a few times with the new screen and it still is not working. I tried my old one again for good measure, it did not work at first, but then I removed and cleaned them and then it worked. (Whew!) I’m confident that I know how to get the connectors in correctly. I do think that there's just an issue with the new screen. I have a replacement on order that should arrive soon. Thank you so much for your help, I very much appreciate it.
さんによる
コメントを追加
回答を追加する
Cornelius さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 27
今までの合計 87
