メインコンテンツにスキップ
Released April 17, 2020 Model XT2041-4, XT2041-6, XT2041-7, XT2041DL
22回答 すべてを表示
front camera not working, in diagnostic test it fails
at first it worked with message showing 1431111 like but i haven't memorized exact number, with some of camera features failure messege.
Now camera not working at all. i am from pakistan and there is no outlet of motorola in pakistan, as it is not launched here, i am using refurbished motorola set.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@mudasirhussain if the camera fails in diagnostics, replacing it would be a good start. Since iFixit does not yet have a guide for that, use something like this video to work on it. Cameras are readily available at many online stores.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Dear, my camera issue is not hardware related. Its software or application fault
さんによる
@mudasirhussain How did you come by that conclusion? The diagnostic tests are not there to test software; they verify the hardware is functioning correctly. If a component fails a diagnostic test, then that component has failed, not the software that accesses or controls that device.
I would suggest you follow @oldturkey03's advice and start by replacing the camera, but you can always satisfy yourself that it's not a software problem by wiping the phone back to factory settings. If it works there, then and only then you can say it's a software problem; otherwise in the opinion of at least a couple of guys with decades of experience, it's the hardware.
さんによる
コメントを追加
回答を追加する
Mudasir Hussain さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 11
今までの合計 58
