メインコンテンツにスキップ
2020年10月15日に発売されたGoogle Pixel 5スマートフォン用の修理ガイド。
48回答 すべてを表示
Screen is black on google pixel 5
I replaced the battery on my Google Pixel 5 and it's screen stays black when i try to boot it. When I push the power button, it vibrates, but nothing else happens. Any idea as to why it's not turning on? I did everything according to the instructions I was given by a Ifixit.com. Except I messed up the pull strips on the batter and may have punctured the black lining underneath it but it wasn't too bad. When i was prying it open i preyed a bit to much to the top so i remove the plastic bit on the bottom of the screen. I ended up adding adhesive to stick it together but it didnt make a crunch sound when i pushed down the screen.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
So basically I think this might be a display issue. You said you fractured the cable that shows the display and have probably damaged it so much that you're going to need to get a new display and install it.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yeah i double checked the cable i think its fine. I have edited it a bit
さんによる
コメントを追加
回答を追加する
Jerry26958 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 16
今までの合計 45
