メインコンテンツにスキップ
2022年2月25日に発売されたValve製の携帯ゲーム機「Steam Deck」の修理・分解・トラブルシューティング情報です。型番1010で識別されます。
My Up Dpad isn't working
My steam deck up directional button is not given any input or not working at all. My other buttons on my steam deck does including the left, down, and right d pad inputs. I took it apart to see what was wrong with it I can't seem to brainstorm what's going on as everything looks normal inside. So what I need a new membrane Dpad or the entire left bumper board with the d-pad cable?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Yes I'm having the exact same problem my up Dpad dosent work at all but the rest does have you found a solution to this situation I even bought a new Dpad cable still dosent work only the left right and down works.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had the similar issue so here is the solution log
Issue:
Steam Deck D-Pad "Up" button stopped working. Instead, the Steam and Quick Access ("...") buttons acted as if the "Up" direction was being constantly pressed. Problem persisted even in BIOS, so not OS-related.
Symptoms:
  • "Up" on D-Pad unresponsive
  • Steam and Quick Access buttons behaving like D-Pad Up
  • Input was stuck in a loop, spamming "Up"
  • Occurred even before boot (in BIOS), so not software-related
Fix (worked for me):
  1. Powered off the Deck completely
  2. Opened the back cover
  3. Located the D-Pad ribbon cable (marked “D-PAD” on the daughterboard)
  4. Disconnected the D-Pad ribbon cable from the connector
  5. Booted the Deck with the cable disconnected to confirm buttons behaved normally again
  6. Powered off, reconnected the D-Pad ribbon properly
  7. Booted back up — everything worked normally again
Theory:
It might not have been a physical connection issue. The BIOS input controller may have glitched and started misinterpreting D-Pad input — causing "phantom presses" and remapping behavior. Disconnecting/reconnecting the ribbon cable likely forced a soft reset of the controller's state. So the root cause may be firmware-related, not hardware failure.
Conclusion:
Bad input state or firmware glitch caused phantom input. Simply reseating the D-Pad cable forced the controller to reset. No need for cleaning — just unplug–replug.
Hope this helps someone avoid replacing half their Deck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Damien Boozer さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 29
過去 30 日: 157
今までの合計 472
