メインコンテンツにスキップ
Repair and additional information for the Samsung RF263AE refrigerator—a bottom freezer model without an ice-through-door feature, accessible via both drawer and door, and equipped with an anti-sweat heater switch. This page covers information for model numbers matching the pattern RF263AE**.
1回答 すべてを表示
Ice build up on rear of refrigerator near evaporator intake
Problem
I have a large chunk of ice forming on the rear panel of my refrigerator. It is near the evaporator, but not on the evaporator panel itself.
I used a FLIR to see what's going on.
The dark spot is -10ºC, and it seems to be the tube feeding cold refrigerant to the evaporator up from the condenser.
Things I've tried
Cleaning condenser coils and filters
They were actually not too bad. Condenser fan is working fine
Defrosting
I have tried doing forced defrost cycles. No change apart from going slightly crazy from the beeping. I have run about 5 cycles, and unplugged the fridge for a couple hours.
This got the spot up above freezing, but I suspect that the tube behind it is still very cold.
I also tried using a heat gun for about a minute on the plastic in front of the cold spot. This was not very effective.
Defrosting evaporator
I popped the evaporator cover panel off and unplugged it. The evaporator radiator was actually not bad. It had only a little bit of ice on it, and no ice in the drain pan. The evaporator fan itself is clean, free of obstruction, and moves freely.
Replacing some of the weather-stripping/seal around the evaporator cover panel
Some of it looked like it was not in great shape, so I replaced it with some new foam weather stripping.
I did not replace all of it, but only the part on the right side of the panel, nearest to the cold spot.
Not sure if I should bother doing the rest. It looks fine, and it didn't seem to make any difference.
Tested evaporator fan
I used a magnet on the front of the fridge to simulate closing the door. The evaporator fan kicks in pretty quickly, and sounds normal. I feel cold air coming from the vents in the front.
Isolating the cold spot from potential sources of air and moisture
I went a bit off-script on this one. I thought there might be moist air blowing on this spot from the evaporator cover vents. I actually think that the vents on the side are probably for intake, but I gave this a shot. I took some plastic, and taped it to the back of the fridge, blocking the spot that ices up from the evaporator cover.
This had no effect.
I then did the same thing and closed off the water filter from the trouble spot.
These are not hermetic seals, but I expected to see some condensation build on the plastic, if this were indeed the source of the problem.
Anyone have any ideas?
Is the spot supposed to be this cold?
What could be the source of the moist air blowing onto it?
Update (02/11/24)
The seals look okay. That is, except for the front seal between the doors. There's a torn section I noticed a few days ago, but I've taped it up for now.
I asked this question on another forum, and it was suggested to me that the issue might be compromised insulation. Still trying to learn what that means.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @kirillbirger,
Have you checked if the refrigerator door seals are OK?
If there is a leak through the seals anywhere, the air will condense more on the coldest spot in the compartment.
Place a sheet of paper between the door and the door jamb and with the door closed normally i.e. no pressure on it by you to keep it closed, try pulling the paper out.
It will come out, but not easily and it should definitely not fall out by itself.
Do this at various places around the door, top, bottom and both sides.
Update (02/11/24)
Hi @kirillbirger,
Did you try the paper test on the patched up seal section?
Also check the door alignment to make sure that it is straight and parallel to the cabinet and that it is not a hinge problem.
Compromised insulation might mean the insulation that is sprayed between the inner and outer walls of the refrigerator (and doors) during assembly, once the piping and wiring have been done. If this has deteriorated for whatever reason there's not much you can do except replace the door if it is in the door or replace the whole refrigerator if it is the cabinet
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Sorry, that is what I meant by my update. Yes, I did the paper test on all parts of the seal. I was very hopeful this show me a problem, but the seals are all tight.
I will check the door alignment today.
Given the cold spot, would you agree that it is likely an insulation issue? The issue would be in the cabinet, given the location of the cold spot.
さんによる
@kirillbirger
It's looking like it but just to verify that it isn't a seal or an air leak problem anywhere else, turn on a flashlight and put in the compartment and close the door. Then turn off the lights in the room and check if you can see any light coming out from the refrigerator. Might be easier to see if there is or not if you do this at night.
さんによる
コメントを追加
回答を追加する
Kirill Birger さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 115
