I have broken screen shows no pictures
Need repair or if not fixable need a used replacement
Hi Jack,
If you're looking for someone to fix your phone for you, I'm afraid you're in the wrong place. iFixit is dedicated to providing information, tools and sometimes parts to empower people to repair their own devices.
If you just want a repair shop, go online and search for shops that repair your particular phone. You can find either local shops where you can drop your phone off, or online services that provide mail-in delivery and returns.
このアンサーは役に立ちましたか?
@jackstewar25759 like my colleague @dadibrokeit already said, iFixit doesn’t actually fix things for people.
The site is a place for people to learn repair for themselves—the “i” in iFixit is you! On here you will be empowered to fix your own device and save your hard earned money.
The repair needed sounds like a screen replacement.
For this repair, I’d start with a DIY video like this As you can see you don't even need to heat the back cover. Straight forward repair. Replacement displays are readily available at many online stores like this and are not very expensive. Get one with a mid frame attached so you will not have to try to remove the old screen from your old midframe. It'll make this work straight forward. You can do it!
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 15
