メインコンテンツにスキップ
Repair information and guides for Amana dryers.
4回答 すべてを表示
My thermal fuse keeps blowing in Amana dryer despite best efforts
I, being the broke man I am, have a cheap dryer (Amana model # NGD4655EW). It worked fine for three years though, not drying loads super well but getting the job done. About three months ago the thermal fuse blew, and I learned a lot about dryers to fix it cheap because, again, broke. I replaced it, cleaned everything, and made sure it worked well. It worked great, drying plenty more laundry until two days ago when the fuse blew again. I, confused, checked everything else and it was just that. Air flow seems fine, heating element kicks on and off as needed, continuity on all the other doodads in the back are great. I replaced it once more, and it's blown again.
I am going insane here. I'm cleaning out the whole thing every time I take it apart, and I replaced the dryer hose. I can't clean the ducts in the house as I'm renting but they seem clean enough for air flow for me. I've felt outside and it has warm air.
What do I do or look at? I don't wanna do redneck maintenance and just bypass the fuse, and I REALLY don't want a drying rack, but dryers are expensive. Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @haynco
There are 3 temperature controls in the dryer.
The cycling thermostat should regulate the temperature by turning the heater on and off so that the temperature remains fairly constant throughout the drying cycle (not the cool down time though)
The hi-limit thermostat is as it name implies there to stop the temperature from going too high.
Lastly the thermal fuse is in case neither of the first 2 thermostats are functioning correctly and is a safety feature designed to prevent fires from occurring. I agree with you that bypassing this fuse is not a good idea
You could have a faulty heater element i.e. sagging or broken and is touching the frame somewhere so that the thermostats can't perform their function but the thermal fuse will due to the extra current flow through the fuse
Disconnect the power to the dryer and then disconnect the heater element and use a DMM (digital multimeter) to check if it is OK or not. Not really sure but you should measure somewhere between 10-25 Ohms for the heater coil. Also measure between each connector on the heater coil and the frame. You should measure OL or infinite Ohms i.e. open circuit.
It could also be an air leak in the dryer e.g. blown seal. The cycling thermostat is on the blower wheel and if there's a blown seal then any air that is sucked in through the leak is detected as cooler air allowing the heater to run hot.
I realize that you said that you're broke but here's a parts list mainly to help you to identify or locate any parts and which has their part number. If you do decide a part has to be replaced search online using the part number only, to find suppliers that suit you best as prices can vary a lot between different suppliers.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Haynco さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 16
過去 30 日: 79
今までの合計 320
