How do I reattach the sliding door?
I cant figure out how to get the rear main rail back on the track
There should be adjustments on the other attaching points that will allow for you to manipulate the install process enough to take care of the rear rail first the attach the other points and then properly adjust. If you do a Google search on this there will most likely be a video.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 17
