メインコンテンツにスキップ
Ethernet is a widely used computer networking technology that allows devices to communicate with each other over a network. It is commonly associated with twisted pair cabling, which is a type of cable that consists of pairs of insulated wires twisted together to reduce interference.
Ethernet wire connection to wall mounted box
Where exactly can I put the two wires that come from telephone line to this connection box?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @natnaelfisseha
Usually there's 4 pins in an RJ45 socket when used as a telephone handset socket and the telephone wires connect to pins 4 and 5 (the middle two pins) when viewed from the front of the socket i.e. pins count Left → Right 1→8 but 1 & 2 and 7 & 8 are missing
Assuming the holes leading to the pins (where the wires are in) number 1, 3, 5, 7 on the back row (closest to pins when viewed from the back as seen in your image) and 2, 4, 6, 8 in the front row then the telephone wires would connect to the red and green wires.
If the telephone service is connected you should hear dial tone if you plug a telephone into the socket.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Natnael Fisseha さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 12
今までの合計 183
