it won’t turn-on
it wont turn on , i think it ran out of battery,the adabtor is working i tested it , but it wont recharge the battery.
@roozbehd check your power supply first
After that check your DC in Jack. Make sure there is no corrosion, damaged pins or debris in the jack. You can always use a few puffs of compressed air to clean it. If your power supply and your jack are okay, it'll be time to open your Lenovo up and check the DC in jack to ensure that it.
a. receives power from the power supply,
b. that everything is properly connected.
Now is also a good time to check the battery for any swelling etc. You should consider changing it since there is a possibility that his is/was one of the issues.
Use this Lenovo N23 Hardware Maintenance Manual to work on your Yoga
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 33
