My canon iVIA HF 20 is not working
My camera canon iVIA HF 20 is not switching on. I think it has software problem because it happen after double command. What should i do please guide
@mairmajalis if you feel that this is software related, try this. TRy to reset your camera to factory defaults remove the battery and press the [Reset] button located on the side of the camcorder by using a small object such as a pen point.
After pressing the button reinstall the battery or connect the camcorder to AC power and turn the camcorder on. After the camcorder powers on reset the date and time and resume use.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 34
@mairmajalis explain what you mean by "happen after double command" It worked before until this "double command"?
oldturkey03 さんによる
