メインコンテンツにスキップ
Repair guides, user manuals and services for the Asus ROG Zephyrus G14 laptop. The Zephyrus G14 is a 14-inch Ryzen-powered gaming laptop, first released in mid-2020.
keyboard is dead and backlight is flickering
Hi, some history of my g14 2022, after 10months, my lcd started to have lines, had it replaced by the shop i bought this from. then in one of my travel, my laptop bag fell with my g14 in it, after that, the keyboard stop working adn there is also a slight backlight flicker
. i had to use an external keyboard. i tried to have the keyboard replaced but the repair shop said even with a new keyboard, it still doesnt work. any lead will be appreciated
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@walterjrgarcia the backlight flickering and keyboard not working could be a torn, loose cable as well as damage to the board connector etc. I suggest that you take a look at those things first. Remove the bottom case as show in step one on here Asus ROG Zephyrus G14 Thermal Paste Replacement check closely for any damage. Post some pictures of what you see with your Question. That way we can see what you see. iFixitでの質問に画像を追加する方法
Worst case scenario would be a new keyboard (upper case) or even a new motherboard. Let's check this all out first.
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
Asus ROG Zephyrus G14 Thermal Pasteの画像
ガイド
難易度:
中レベル
45 minutes - 1 hour
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Walter Jr Garcia さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 15
今までの合計 396
