kweku Jay @kwekujay
評価: 1
投稿日: 2024年1月24日
My Two fans work perfectly.
My water system also works but heats up quickly. It makes my car overheat and moves very slowly.
この質問は役に立ちましたか?
James Van Damme @col_panek
評価: 676
8
First step: your thermostat could be stuck closed. See if the radiator gets hot. If not, take the thermostat out and see if that fixes the heat. It should run cold then. If not, you might have a bad water pump.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 32
