What is the size of screw bolts?
What is the size of screw bolts of Lenovo ideapad 100-14IBY
@jaelouieta21349 there are quite a few different screws and you are not being specific to which part you are referring to. Since the question was left as an answer to a different question, which dealt with a bottom cover, I can tell you that the bottom cover uses (7) M2 X 6mm and (2) M2.5 x 5 mm
For all the other screws use the Hardware Maintenance Manual for your computer. All screws are listed in that.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 22
