Why doesn't tub completely dran after spin cycle?
Tub agitates, spins, drains, but some water is left at the end of the spin cycle. Why?
So the washer works fine except doesn’t drain all the water. First take notice of the drain hose. Is the water coming out fast as usual? If not, there could be a partial blockage in the hose or the water pump maybe going out. Also, the water valve maybe leaking water back into the tub.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 22
Hi @ericanders82064,
What is the model number of the washer?
How much water is left in the tub at the end of the spin cycle?
jayeff さんによる
