only using 2gb ram from 4gb ram
my laptop has 4gb ram (probably 2+2gb) but one day one of the ram became unusable and still is not usable. thanks in advance for helping me.
The answer to this is very simple: open up your laptop and replace the RAM. 4GB is not very usable today, and your system supports a maximum of 8GB, so while you are replacing the RAM, it's a good idea to do a simple upgrade. Look at page 5 of this manual. It will tell you how to take out your current RAM and replace it. A good replacement/upgrade I have used for computers before is Crucial 2x4B DDR3 Laptop Memory. I have used it before in multiple laptops, and highly recommend it.
Follow these instructions, and you should have 8GB of working RAM, maxing out your system for around $30!
EDIT: Do not throw away either of the old RAM cards, keep them as a backup in case you need them. Spare parts can come in handy later.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 63
Hi @yunij41,
have you tried finding out which ram module is faulty by buying a replacement ram module to see when both work OK?
What have you tried
jayeff さんによる
