My speakers aint working.
My laptop speakers are not working. I have to plug in my headphones to listen to music, what might be the problem and how to fix it?
@emporerdavey the problem could be your headphone jack. It is possible that it does not "switch " to the speakers when you disconnect your headphone. Sometimes a few drops of isopropyl alcohol followed by a few puffs of compressed air and then inserting and removing of the headphones in rapid succession may free a stuck contact.
OF course, there is always a possibility that this is a bad audio amplifier on the motherboard as well as bad speaker assembly. Try the headphone jack first. After that, you would need to disassemble your laptop and check the connection of the headphone jack for bad solder joints, failed components etc.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 20
