メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Brief one or two sentences with identification info. Example: Released June 2009, identified by model number A1303.
Tv not turning on. Just click on/off and standby light blinking
Hello. I just bought myself a defekt LG oled77A16La. The tv wont turn on it just click on/off with 2-3 second between, continuously. The standby light blinking continouesly aswell. What i tried already: i tried to disconnect the cable between power board and mainboard, it just stop clicking but still dont turn on, and No standby light on. I also tried to change the mainboard with another mainboard from a 65 inch , all the cables fitted in but its not the complete same board, the result was the same, just clicking on/off and blinking from standby light. Do you think the problem is from power board or mainboard?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
8 件のコメント
@mbmb37001 is this the board that had a blown fuse? If so then that is an important detail.
さんによる
No, this is another tv 🙂
さんによる
@mbmb37001 ;ast picture where the two ribbon cable go under the sheet metal. Take that off and lets see. Have you disconnected the panel yet?
さんによる
Ok i have send fotos of everything. Also i have done a tjeck with multimeter. I have standby voltage 11,55 going to mainboard. Standby voltage is 12 on this tv.
さんによる
What do you mean by disconnect the panel? If it is the screen you mean, then it is glued on this OLED tv.
さんによる
3件以上のコメントを表示
コメントを追加
1 件の回答
最も参考になった回答
@mbmb37001 "disconnect the cable between power board and mainboard, ......but still dont turn on" is actually correct behaviour. The power supply needs a pull-up resistor to start.
Measure the voltages on the connector from the power board to the main board. Let's see what your power board puts out and what your main board tells the power board to turn on. Start diagnosing form the back to the front. It is possible that this is a bad power supply but every other board can have the same symptom. Also, this may be neither. Disconnect the ribbon cables on the panel and see if it changes the startup behaviour.
Post some good pictures of the back of your TV (cover removed of course) so we can see the board layout and then post a couple of good pictures of all of the boards. WE can try and check the components, and maybe even find TP where you could measure some voltages. etc.
iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have this same problem but I get a black screen with the back light on and a single green vertical line on the right side of the panel. And I hear a click it turns on no picture/black screen. With the green vertical line and With back light on and work. 2 or 3 sec then off it goes..
I've checked the voltages it's says that the 23v to the tcon board it at 20 and I think it's supposed to be 24v on those line of yellow capacitors at the bottom of the power board.
So that would mean main board is good then right. And tcon I guess could be the issue and the 24v basically it needs to power the OLED is the issue I imagine..
Idk throw me some ideas.
I'm thinking it could be the line of yellow and black 35v 1000uf caps on pwrboard
さんによる
コメントを追加
回答を追加する
Mb Mb さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 14
過去 30 日: 59
今までの合計 1,231
