Fat yellow non see through spot on tv screen
Is it possible to repair spot on led screen? Probably pressure damage.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@antonspoper6499 big depends. We will have to see what this looks like. If the screen has broken LCD's/LEDs then it is not repairable but needs to be replaced. Post some images of what this looks like with your Question. That way we can see what you see iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
Just added a photo
@antonspoper6499 dang! That is your display. Looks like some bad LCD/LED This is a 75" screen, it'll cost you more than a new TV, if you can even get it. Double check your warranty and see if you can still get Samsung or the seller to help with that. Otherwise, try to getting used to seeing that spot.
If it is an NU model, Samsung did have issues with the panels on those.
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 22
