Power button broke, not powering on.
I opened the the headphones and the power button that is on the motherboard broke off. How do i fix?
Hi @chaseskii
Find the power button and put it back on with glue, or if not buy a replacement and put it on with glue. If you are unable to buy a replacement button then get a replacement headphones or use a small tool to click the button
Curious to see what happens, Cheers!
このアンサーは役に立ちましたか?
@chaseskii it'll depend on what it looks like. Take some pictures of the damage etc and post those with your Question. That way we can see what you see. It might be possible to source a switch that will fit or even to bypass the switch altogether. Maybe even connect an external switch. Like I said it all depends on what this all looks like.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 7
過去 30 日: 65
今までの合計 226
