AC port broken, need new one
Where do you buy AC ports for the Wii?
@daneelliottd532 those are still available, but you must identify your console properly. Due to different variations of the console the connectors are also different. EII 2P AC connector and here the WII U2 AC jack etc.
このアンサーは役に立ちましたか?
My console is the original WII. For the first link, con you bend the metal ends?
@daneelliottd532 your current connector has the L shaped connectors in the back?
Yes. I think mine is the 99 degrees
I meant 90 degrees
@daneelliottd532 post a picture of your AC connector with your Question. That way we can see what you see and hopefully match it up. iFixitでの質問に画像を追加する方法
i guess you should watch out on second-hand market
however, maybe its possible to solder?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 53
