メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年10月15日に発売されたGoogle Pixel 5スマートフォン用の修理ガイド。
Pixel 5 antena replacement alternatives
My Pixel 5 detects my sim, but no signal at all on both my physical and esim after a minor water damage. WiFi works, I just can use the sim because it shows no signal at all. After some research I suspect the antenna is damaged, are there any alternate antennas that I can replace it with?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント:
I just can't* use the sim because it shows no signal at all
さんによる
@russellpeiris
Have you fixed the water damage?
さんによる
Yes, the water was removed, and some components in the charging area was cleaned, it seems the antennas are not damaged, the technician suggested it might be an issue powering the signal, I'll be handing over the phone to him for further inspection (inspecting the ic and stuff)
さんによる
same story here after water damage , mine also don't wanna open cameras anymore ,modem is probably most sensitive and most exposed on the board
さんによる
コメントを追加
1 件の回答
Hi @russellpeiris
It seems the answer is your antenna is not powered due to water interference/damage
you should replace the cable to the antenna
let me know of any further developments
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Russell Peiris さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 28
今までの合計 317
