メインコンテンツにスキップ
Shark Rotator Powered Lift-Away XL Capacity, model NV755. It can convert from a push vacuum to a hand-held vacuum. Repairs and troubleshooting found here may also be applicable to models NV652 and NV752.
23回答 すべてを表示
Replace HEPA filter, What specs tell if authentic HEPA filtration?
Thanks for reading my question. I need to buy a replacement HEPA filter for the shark nv752 rotator powered lift-away. What specifications on a nv752 shark-compatible replacement filter would state if filter provides authentic HEPA level filtration or not. The descriptions I found just state that the filter fits--not that it provides "HEPA" level filtration.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @sue_59
It's a bit hard unless they actually state the specifications of the filter or the filter grade.
Here's a link to one supplier where they state that it is a HEPA filter and that it retains 99.95% of dust and allergens down to 0.3 micron size which according to this is the requirement for a medical grade HEPA H13 filter.
Searching online it seems that most of the different filters that are made by the manufacturer mentioned in the first link above and are advertised as HEPA seem to meet the H13 standard.
The supplier link was only to show what to look for what is stated about the filter if it doesn't mention the actual HEPA filter grade
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you for answering my question and doing all that research. . It was very helpful to know that HEPA filters have different ratings. The link to the article on "different grades of Hepa Filters' was very helpful in explaining the different grades-- especially H11-H14. However, when I searched for the rating of the oem nv752 filter --Model:XHF650 filter-- I could not find the HEPA grade.. Now that I have this information about the different grade ratings, I will try to find out the grade or my oem filter or just look for H13 standard as you suggest. Thanks again.
さんによる
コメントを追加
回答を追加する
sue byrce さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 43
