كيف تغير مدخل الشحن
كيف تبدل مدخل الشاحن
English translation:
Title: How to change the charging port
Description: How to replace the charger port
You are fortunate that the charging port on your phone is mounted on a separate daughter card so replacing the charging port is relatively easy and doesn't require any soldering (although you can if you want). I wasn't able to locate any iFixit-style step by step written guides, but there are video tutorials available such as this one.
Samsung A20s charging problem solution
The daughter cards are readily available online; I suggest starting with sites like Amazon, eBay and AliExpress, but there are others as well. Here's one of the first ones that came up on my cursory search.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 32
