メインコンテンツにスキップ
Discover repair information including guides and tips for Whirlpool Refrigerators. Our comprehensive resources offer detailed instructions for troubleshooting and fixing common issues in various Whirlpool refrigerator models.
86回答 すべてを表示
WRX986SIHZ00 Why is my ice machine not dispensing ice?
Ice forms in the mold but them melts away.
Service testing results
Service test 15 ice level sensor - correctly displayed saying not filled
Test 36 ice box fan: have a swooshing sound. Like it will blow air and then not. So we replaced it. First day of replacement overnight it made and dispensed ice.
Test 37 ice box thermistor: 01, pass
Test 45 Ice maker water fill test: water came out front of ice box, going to assume that’s good
Test 56 ice maker error codes: E0
Test 57 ice maker harvest: runs its cycle
Test 58 ice maker heater activation and thermistor: goes from 00 to 10 (not sure what it means)
Test 59 ice maker motor: runs its cycle
What could be the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @jvb92859
Try running service test #18 Ice Door Motor and check if if it is OK.
If the ice door doesn't shut properly, warmer air can enter and it may not get cold enough in the ice maker to produce any ice.
With regards to Test #37, I think that this test (along with Test #58) just verifies that the ice box thermistor circuit is working within specifications and not that the actual temperature in the ice maker is OK to make ice.
By this I mean that it tests that the circuit is not open circuit i.e. OL or ∞ Ohms or short circuit i.e. 0.00 Ohms and that the resistance is somewhere between ~8K Ohms (resistance for 36°F) and ~23.4K Ohms (resistance for 0°F).
For example if it measured 23 K Ohms when there was actually still water there then this may be the reason why the fan is turned off. It doesn't have to be operated to keep the area cold as the control board thinks that it is cold enough
Perhaps measure the resistance of the thermistor at the main control board to see what it is. Disconnect the power to the refrigerator and unplug the P8 harness cable from the board and measure the resistance between pins 1(orange wire) and 2 (white wire) on the harness cable plug (not the board)
¹ Thermistor resistance values as per the tech sheet for the refrigerator.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
JVB さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 25
今までの合計 83
