Why its give me Black screen with blue edges and vice versa every time
Black screen with blue edges and vice versa every time I turn it on
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @bx44
The power board seems to be OK as it turns on and there's backlighting. You could always inspect it for any obvious component damage e.g. blown capacitors or heat stressed components etc.
I think though that there's a mainboard problem.
Here's a teardown guide that shows how to disassemble the monitor that may help.
Try replacing the mainboard (supplier example only) and check if that resolves the problem.
If you decide to do this, verify that the board you order has the same model number or part number as the original. Usually this is found either printed on the board or on a sticker on the board
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 6
今までの合計 73
2 件のコメント
Hi @bx44,
Can you view the monitor's OSD menu screens OK?
Have you tried using each signal input port i.e. HDMI & DP?
jayeff さんによる
@jayeff It shows the same thing no matter how much I connect it to any device and it also does not show the OSD menu of the monitor
Bx4_4 さんによる
