When I tap the back of my DSI console, it turns off
When i tap the back of the dsi console it turns off and it s annoying because i put it in the table and it turns off, i wanted help to know what is happening so i can fix it
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Remove the battery cover and make sure the battery is correctly in its little “hole”. Make sure the contacts are clean.
このアンサーは役に立ちましたか?
im gonna do it when i get home, however i dont think thats the issue as i already changed the screen andi removed the battery for that, but the issue still continues, im gonna try to clean the contacts and im gonna tell you once i do.
@coisas Did you remember to close the ribbon cable latches?
the cleaning worked
also my left button has a bad response, sometimes it works sometimes not, how can i fix it
and yeah i did close the ribbon cable, i always do these type of stuff really carefully
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 66
