Acer Aspire 3 A315-56-308m The motherboard repeatedly shorts
Hello, i would like to ask something
The motherboard repeatedly shorts out even after removing the battery.
It shorts out after 1sec and again, repeatedly.
Nothing seems burned. And i tried unplugging everything and it is still doing its own thing. I dont really know what to do next.
Laptop info:
Motherboard: FH5LI LA-J801P
CPU: Intel i3
Thanks for replies.
この質問は役に立ちましたか?
2 件のコメント
Hi @thevampir,
What do you mean by "shorts out"?
Does it continually turn on and off or what?
Disconnecting the battery and assuming the charger is also disconnected should mean that it can't do anything as there's no power to do so.
jayeff さんによる
Hi, Thanks, for the reply
The Laptop won't even turn on. I have laboratory power supply, that will show me if the motherboard shorts out, so when I put voltage on the laptop input, the laboratory power supply is telling me there is a short.
And i disconnected the battery, because i wanted to see if the battery was the problem, but it still shorts out.
And what i mean by Shorts out? I mean that maybe there is a Diode that is bad and isn't doing its work, and i didnt find any bad ones that i can measure, or some integrated circuit that is telling the motherboard when to use the battery, and if it tries, the motherboard will short out.
I hope I wrote it well, English is not my first language
Thanks, for the help.
The Vampir さんによる
