Both brewing options pump the same amount of water
Hi. After cleaning/descaling the machine, both brewing size options pump the same (larger) amount of water. Is there a fix for this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Try resetting to factory settings: Switch it Off, then On again and press and hold the "Lungo"-button for 5 sec. (The right one). The button should flash three times. The machine will heat up as before - and hopefully the issue has disappeared. Here a Video.
このアンサーは役に立ちましたか?
Thank you; that was what it needed 🙂
Well done! Small cause, big effect. ;-)
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 39
