メインコンテンツにスキップ
The Samsung Galaxy A10 is an android smartphone developed by Samsung Electronics. It was released in March 2019.
My phone was submerged in water from the bottom
My phone wasn’t totally submerged in water but the bottom part was for about 3 seconds
After draining the water out and putting in rice, it still hasn’t come on. What do I do now?
Is there still a chance it’ll work
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Thank you very very much
Met with a phone engineer earlier today and was told to replace the phone panel. I don’t know if this is possible
さんによる
コメントを追加
2件の回答
ベストアンサー
Don't put it in rice, that does not help. It needs to be dried out as fast as possible. Put a fan near the charge port and blow warm air into the phone. Do not try to charge it until it is fully dried out. It is best to disconnect the battery as well. If you aren't able to, then find a shop that can. If fully dried out and no corrosion has started on any of the circuit boards, there is a chance it will come back on. Good luck.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
@teegirl Rice does not work. It does absolutely nothing to help you with this repair. All it does is waste time and waste food. Check here https://www.ifixit.com/News/30047/rice-i... for more on this.
For now, you must stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your phone. Since iFixit does not yet have a guide for the main board removal, use something like this guide You will also need to remove the charging board (which is the board with the USB power port etc.) For that use this guide Samsung Galaxy A10 Charging Port Replacement Personally I would not clean the charging board but repalce it since that is most likely the boards that got the most water damage. As for the main board, you will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board.
Take a close look at all components and connectors. Truly assess the damage. Look for even minor corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave the board to dry for a day etc. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned. Replace the charging port and do not forget to replace the battery. It will fail if you do not take care of it now. This is a must and not an option Samsung Galaxy A10 Battery Replacement
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess.
Letting the water dry is the wrong thing to do. Water itself is not a conductor and would not harm your electronics but leaving it to dry, deposits minerals and salts that are conductive and corrosive. Those will lead to destructive failure. Always clean water damage!
Repair is War on Entropy!
iPhoneの画像
ガイド
iPhoneの水濡れ・水没ダメージからの復旧方法
難易度:
難しい
1 - 2 hours
Samsung Galaxy A10 Batteryの画像
ガイド
難易度:
中レベル
50 minutes - 2 hours
Samsung Galaxy A10 Charging Portの画像
ガイド
難易度:
中レベル
25 minutes
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Teegirl さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 155
