メインコンテンツにスキップ
Repair guides for the Samsung Galaxy Tab A series of tablets. Released in 2015.
483回答 すべてを表示
Why is my Samsung tablet showing the battery sign when plugged in but
So basically I would put my tablet on charge and I would press the power button and it would show the charging signal on it but when I take it out it won’t turn on or even show that I need to charge it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@disha43291 that is what can happen when your battery no longer takes a charge. Your tablet shows the charging symbol because it is trying to charge the battery, but once you disconnect, it'll turn off since the battery is unable to hold a charge. I would suggest you start of by replacing the battery, then re-evaluate.
You did not tell us what exact model your Tab A is so we can't help you with the battery replacement.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Disha さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 57
