メインコンテンツにスキップ
電球および周辺器具の修理とインストール情報
153回答 すべてを表示
antimosquitoes g23 bulb/lamp
I have an antimosquitoes lamp (from aldi or lidl), bulb form is G23 but i don't have enough info from bulb or the lamp.
I understand light type has to be Actinic/BL as it is the one used to attract mosquitoes.
And in the lamp i can measure a power around 90V.
Most g23 bulbs on internet doesnt have specs about its power/current. Why?
What type of lamp should i buy?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
@alcrepaircafe I am probably misunderstanding your Question here but anyway. Here are the measurements for the G23 light base
110V or 220V starter and capacitor inside for the G23 base. Since you measured a lamp voltage of 90V you could check the rest of the electrical values on here
At 90V it should be an 11W bulb.
Hope this is at least slightly helpful
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
i had some mistakes on questions, i just edited it ;)
Yes it must be 11W as per consumption at label.
So the same lamp can work on other voltages and therefore different Watios?
さんによる
@alcrepaircafe that looks about right.
さんによる
コメントを追加
回答を追加する
AlcRepairCafe さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 10
今までの合計 31
