メインコンテンツにスキップ
廉価版で携帯バージョン、統合されたJoy-Conコントローラと若干縮小したスクリーンを持つNintendo Switchハードウェアです。2019年9月20日発売。
175回答 すべてを表示
Switch wont get past the nintendo logo
So I bought a 2nd hand switch and it doesn't charge properly nor turns on properly.
When I plug it into the official nintendo charger I got, the battery icon with the charging (thunderbolt) icon shows up for a few seconds and turns off, and shows again after a few seconds. It just keeps looping until I disconnect the charger.
Sometimes, pressing the power button shows me the nintendo logo (not the nintendo switch logo). It shows for a few seconds then returns to just showing the battery icon and dissapearing.
I've successfully turned it on a couple times. The most consistent way I found was to flip the switch upside down and keep pressing the power button while removing and inserting the sd card till it turns on, but it wouldn't stay on for long. When I bump the switch or move it too fast, it just turns off. Otherwise it just turns off by itself after 5 to 10 minutes.
Would it be possible that some cables inside are just loose? Or is it some motherboard or battery problem. I would appreciate any tips that could help me narrow it down.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
if you keep the sd card removed does it boot normally
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
nope, it just helps when I mess around with the socket for some odd reason
さんによる
@zeggyfuentes maybe a bad reader
さんによる
Hmm, ill keep this in mind. Thanks!
さんによる
コメントを追加
What does the board look like? Keep in mind to replace thermal paste after you finish repairing the device.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have no clue what the inside looks like, I never opened it. But when I do, ill keep in mind to repaste it, Thanks!
さんによる
コメントを追加
回答を追加する
Zeggy Fuentes さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 21
過去 30 日: 63
今までの合計 248
