メインコンテンツにスキップ
2020年9月18日発表の第1世代Apple Watch SEの修理・分解情報です。
34回答 すべてを表示
I went for a glass replacement and a cable was snapped
what is the connector/antenna for, do I need to replace it.
Then I am also having issues closing it back the screen keeps on popping off, battery is not swollen or anything still has 100% BH and the Watch works fine
I don’t know if this is the Force Touch sensor (The orange like gasket in the above image), I am planning on adding this black rubber glue used for screen replacement T7000 or B8000
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hey there!
As for 2nd screen, the part you marked on red is just part of isolation sticker, it doesnt really affect the performence if its ripped of, as long as the flex cable stays intact.
About the 2nd problem: Apple watch SE is not equipped with touch sensor, the orange thing you reffer to is just a seal that lifts display a little bit and strengthens waterproof abilitys. Most likely you cannot close it as there are remains of adhisive left on the seal/display, try to gently cleaning it off end then check if its fits perfectly. To permanently seal it try glue b-7000.
Oh and lastly, if the seal is ripped/damaged, you can consider getting rid of it complitly or replacing it, glue should seal watch properly if applyed correctly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Oluwatimilehin Alabi さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 2
過去 30 日: 15
今までの合計 66
